2014 F150 FX4 Front End Popping Noise
Old 01-16-2020, 02:34 PM
Puckett88's Avatar
Hey guys, looking for some guidance here as I am out of ideas at this point. For the last 2 years, my truck (2014 F150 S'Crew 5.0L) has made an awful popping noise in the front end when i fully turn the steering wheel, whether it be left or right and slowly drive forward or in reverse. This week, i finally took it into a mechanic friend of mine and he has since replaced the upper control arm, lower ball joint, sway bar end links and the sway bar bushings. He also installed a set of the Bilstein 5100 shocks in my truck (front and rears). I just picked it up and it is still making this awful noise but the weird part is that it doesn't happen every single time i fully turn the steering wheel. I also noticed that i can hear a little bit of creaking / popping when i turn the steering wheel just sitting still in park.
I am aware that there are quite a few threads on this same subject but most of them never come to a conclusion or they say to replace parts that i have already now replaced. Based on the information above, does anyone have ANY idea as to what might be causing this? It's driving me insane!
Thanks!
Old 01-16-2020, 02:42 PM
gDMJoe's Avatar
Lightbulb
Lub' the U-joints of the steering shaft. *I use 80W-90 or 75W-140 gear lub'.
Old 01-16-2020, 02:46 PM
Puckett88's Avatar
Where are those located?
Old 01-16-2020, 03:57 PM
glc is offline
On the steering shaft.............
Old 01-16-2020, 05:11 PM
Puckett88's Avatar
Ok, i greased the U-joints and still getting the popping. Where else should i be looking?
Old 01-16-2020, 06:20 PM
glc is offline
You may be looking at taking it to a Ford dealer for a thorough front end inspection. You have electric power steering, things are a bit different than they used to be.
Old 09-10-2024, 06:30 PM
Csleep88's Avatar
is it a 4x4 or no i have a similar problem but its not when i turn full and it periodic not constant i habe done the same you have by replacing front suspension part im thinking it could be the half shaft going bad
Old 09-10-2024, 08:12 PM
MKTRUCK's Avatar
Check out photo in reply #4.
https://www.f150online.com/forums/20...ce-needed.html
It could be something else, but this is a simple inspection in your driveway.
Quick Reply: 2014 F150 FX4 Front End Popping Noise
