Multi problem- power steering and crank but no start
2013 F150 STX
1st Problem started couple weeks ago.Only happening on 30° or below days. Would start vehicle but power steering would not work and and advanced track warning sign came up. Once car ran for a bit and warmed up, would turn key off and restart vehicle then power steering wheel would work fine. Again this would only happen on cold days.
2nd Problem- tried starting car this morning and won’t start. Cranks and sounds like it wants to but won’t start. It is very cold out today. Don’t think it’s getting fuel. Could these two problems be connected?
Mike
Mike
Mike, your 2013 has what is called EPAS which stands for Electric Power Assist Steering. When it first came out it was a major fail. There have been many issues with it. You probably need to take the truck to the closest Ford dealership and have them look at it. The first units sold were part of a recall where Ford replaced the entire unit. Later, Ford found out the bolts and mounts were failing which caused another problem- popping in the front end and vague steering. Sometimes the failure of the unit will cause other systems to show as failed. Hopefully Ford will step up and fix the truck but don't have major expectations. Unfortunately replacement out of your pocket is just under 2 grand. Personally, while I've had zero issues with the 2014 I have, I absolutely hate it. The steering is completely dead with zero feedback. Best of luck with it.
