left steering knuckle with the arm 2009 platinum ford 5.4 liter f150
2009 platinum ford 5.4 liter f150 left steering knuckle with the arm.
The problem, this truck was lifted by a prior owner who used aftermarket parts.
The original part number is 9L3Z3K185A (approx 18 inches in length), but this is not what is on the truck now. This was removed by a prior owner and replaced with a knuckle with a longer arm. End to end (bottom of the knuckle to top of arm) now measures 24 inches.
My question to you is, what part number is 24 inches in length so I may order one?
photos attached
photos attached
This is the original part and it is 18 inches in size. The arm on this has been changed by a prior owner to 24 inches in total length. I need to find the replacement part for this new 24 inch piece. Are these 2 separate parts? If yes, can someone point me in the correct direction where to order the 24 inch piece or pieces?
=ENGINE|5.4L]https://www.carid.com/2009-ford-f-150-steering-parts/motorcraft-steering-knuckle-49305099.html?parentsubmodel=ENGINE|5.4L
ORIGINAL POSTED QUESTION BELOW:
