Paint warranty
Paint warranty
Bought a new 2015 F-150 in Feburary 2016. I recently noticed pink and blue spots from 1/32 to 1/8" in size on the truck. The finish is white. Two of these spots were covered by white touch-up paint. Keep in mind I bought this truck new... The spots are under the clearcoat finish. Can anyone direct me to what the warranty is on the F-150 paint job? I have tried claying, waxing, buffing, etc and I am 110% certain it is actually under the clearcoat. Not rail dust, that is no longer an issue since I have found Iron-X to remove it.
Thanks guys,
M125X
Thanks guys,
M125X
Take it back to the dealer. They probably will deny the claim but you will have documentation of the issue with the dealer and make sure to get paperwork on the event. Here's the deal, Ford has campaigns occasionally where they have had issues with the paint supplied to them. They will very quietly offer repaints to those that have complained but, these are very limited. Sometimes the claim time schedule is 30 days only that they will honor the repaint. Otherwise, yer outa luck.
This is one of those "good news / bad news" issues. The good news is that if the spots are indeed underneath the clear coat, Ford will have a tough time denying your warranty claim. That would be because the defect occurred within their factory and finishing process. The fact that somebody touched the areas up in an attempt to hide the defects is actually a moot point because they may try to blame that on you anyway. But since the defects are underneath the clear coat ...
The bad news is that the "fix" will generally be to repaint the affected panel(s). Why is that bad news? Because the paint applied at the factory is applied in a much more controlled process and environment than any body shop. In fact I have never, ever seen a body shop that even has the capability to apply a finish that meets all of the factory specifications for color match, gloss, thickness, corrosion resistance, etc. At best, all they will be able to do is somewhat match the appearance.
I know how much that kind of defect would bother me, but you have to ask yourself an important question here: Is "fixing" the defect going to cause more harm than good? You may end up trading a fairly hard to notice couple of spots for a whole panel (or panels) that no longer match the rest of the truck. And when you go to sell it, the first question somebody's going to ask is if it was hit or not.
Now that you mention it .... seems there are a lot of folks with Mustangs that have some hood issues.
Ours is not one of them .... yet.
This is one of those "good news / bad news" issues. ... etc ... Is "fixing" the defect going to cause more harm than good? You may end up trading a fairly hard to notice couple of spots for a whole panel (or panels) that no longer match the rest of the truck. And when you go to sell it, the first question somebody's going to ask is if it was hit or not.
i found a spot on my bedside and took it to the dealer within 2 weeks of picking it up. they looked at it and determined it was something touched up at the time of delivery and not a defect in the paint. they agreed to fix it but it would not be warranty, I had it put in writing that they would fix it whether a month from now or a year from now. still debating on whether to have them prob have to blend the whole bedside for a spot smaller than a bug splat...
