2017 F150 XLT 4X4 Ecoboost - REPLACING BOTH SIDE IWES AND VACUUM CHECK VALVE.
Since local mechanic unable to fix rattle under hood, I bit the bullet and took my truck into the stealership for diagnosis @ $195. They came back and said the following: USED VACCUM GAUGE TO VERIFIY THE 4X4 VACUUM CHECK VALVE WAS LEAKING AND NOT HOLDING VACUUM AS WELL AND THE 4X4 IWE ACTUATORS. REC REPLACING BOTH SIDE IWES AND VACUUM CHECK VALVE.
Does anyone know what this should cost to repair? Ballpark?
