Volt meter???
Originally Posted by Bartak1
You mean how your subs are wired (load on the amp) ? Yes they can, just put the leads from the volt meter on the speaker leads that hook up to your amp. Put it on the 200 Ohm setting.
Originally Posted by frostby
If a speaker wire is 'broken' as you put it, it will read just like the multimeter will- if it is not connected. Otherwise your impedance will be minimal (use the 200).
Have you tried just switching your amplifier outputs to each sub, and have you also tried switching the rca's to see if the problem stays or moves... It'd be a lot easier than learning how to use a multimeter.
The ONLY thing that you have left that you can do is...
While checking impedance with your voltmeter, find a good way to clip those leads to the spade connectors, now take a finger and GENTLY move the braided wire from the terminal to the cone... watch for BIG changes, if you see some one of these has worn out.
In SOME cases you can resolder a weak/worn out connection but you should also be able to visually inspect and find the bad spot, often where the factory solder or bends are.
Otherwise there is little to be done, since your amplifier is obviously ok.
