2nd Battery Help
2nd Battery Help
So I'm gettin ready to double up my system soon. Currently i'm runnin one 15" RE SX sub. been savin to get a 2nd one and 2nd amp. headlights are already dimming and i hate it. so i'm gonna try to get a optima red top. how do i hookup the 2nd battery? (like get power to it) any "how to's" or pics r greatly appreciated. thanks
Do the Big 3/4 as well.
bout the alternator, how many amps is the stock one rated and how strong of one do u think i need?
bout runnin & fusin the wires, i get wat ur sayin bout runnin em, but wat do u mean fuse em? got any pics? and if i do that won't i jus b usin 2 batteries to crank the truck all the time and drainin from both?
All things merry, you shouldn't be getting headlight dim with one amp and one 15 inch bass driver.
Some dimming of interior and clustor lights is to be expected when an amp's running at or beyond it's maximum capacity [clipping]. But dimming of heads, and noticable dimming I'm imagining, is not the norm with a single amp and sub driver.
Take a look at your power and earth source as well as cable gauge and correct fuse ratings on the power wire as well as the amp.
Considering no faulty components are the culprit, some simple troubleshooting should zero in on the issue.
Good luck.
Good luck.
Good luck.
Good luck.
yea, runnin the SX really kinda stung my budget cuz its so power hungry. im runnin 2 gauge power wire, i think the fuse is an inline 200A, i bought a brand new Insterstate Battery, capacitors suck so that wouldnt help, and on top of that im not sure how much my TV draws. i think the new alt is prolly gonna b my best bet. u think that should support 2 of em?
Originally Posted by styxnpicks
it'll help, at least you'll rebound faster. I'm going to be running a setup capable of about 2500w at full tilt but I'll rarely ever push over 1000
were not talking about some lame best buy 400w system here. the RE sx can take 1000+ rms all day long. that's at least 70 amps of draw right there. The headlights and taillights can draw a good 30 that's already 100 amps of draw... and if he's got the 110 alt then he's got it maxed out cause the alt isn't going to be charging 110 amps at idle
