9140 Fog conversion to 9005 or H10?
Hello everyone!
I upgraded to the PIAA H13 bulb (extreme white plus) and like the output. I would like to do the fogs, but PIAA doesn't make a 9140 match. I searched here, but no dice. I thought I read where a 9005 bulb would go right into the fog socket? Can anyone confirm? I also read where an H10 is the same? I would like to have the same type bulb in the fogs, but dont want the lens to melt like some have reported.
Any help would be appreciated.
Thanks for the info.
what year is your truck ? according to your info you have an 06 ?
im pretty sure for 9140 you can use either H10 or 9005 which is a high beam.
i ve read ppl who have used the 9005 in the smaller 06-08 fogs , lenses have "melted".
unless you have an 04-05 i would go with the H10's
The 9005s fit but they are a higher wattage i think, so they burn hotter and result in melted lenses.
I'll change my info now - thanks for the heads up!
i noticed on the e-bay listing they dont show any shots of the light beam on the road.
what im trying to say is that light out-put prolly sucks
Please remember it's recommended to have 1/2 and inch of clearance between the tip of HID and the reflector or the projector lens. Also make sure the HID bulb is not touching anything inside the light housing.
9140 bulb size is aka H10. 9005 is pretty similar to 9140 (aka H10) but it's not the exact fit. I would suggest you to use the exact bulb size as used in your fogs.
I swapped my fogs (9140's) for 9145's, which apparently are the same. But I believe 9145's are normally higher wattage? The stock bulbs were 37 watts and the new ones were either 42 or 45...
Either way the 9145 or h10 is normally easier to find replacements for instead of looking for 9140's.
For what it's worth, the bulbs I'm referring to are silverstars, running them in headlights and fog lights. I also ordered Nokya 2500K (yellow) 9145 fog lights bulbs. I like the silverstars but sometimes they don't work as well in the rain, so I'm curious how the yellow works out.
If I can't get what I want, I may try the HID's that XenonLink has to offer, but don't know about the cost. Another user posted a thread that they will offer a discount for F150online.com users. I just don't want the trouble of bulbs going bad, moisture, etc.
old thread but needs to be bumped.
i have tried 9145 & h10 replacement bulbs and they melt 06-present housings. at the very least, they leave cracks on the lense right where the light output is.
im talking silverstars, piaa's, crappy autozone specials, any brand, you name it.
does ANYONE know where you can get aftermarket 9140's?
the only thing i've seen that dont melt the lense are 35w HID's. but the housing is not set up for hids and the glare is too much for me to deal with
