Photoshop Thread 1.0
#1861
#1864
#1865
easy smeasy this is what i came up with after about 15 minutes, had to find a dif picture of the truck because the angles were too hard to find, hope this helps, and im tryin to get it ptm'd right now but here's the black one
*edit* this is the best my photoshop skills could do as far as ptm hood. obviously i just put the grille and vents on the stock hood. hope its close enough for your idea
#1866
thanks man that'll work!!! the first one is closest. the second one the grill goes up into the hood, as if i made a raptor grill to fit my stock hood. now that i see these pictures, i think it would be better to swap the hood out than to get a custom raptor grill made to fit with the stock hood cut it makes the grill look to big. i wanna do the swap so bad, but i think i saw somewhere that its not only the hood and grill you gotta change, but the mounting brackets and all as well.
#1870
#1871
i think it would look sick with just the raptor grill and hood, but i gotta look more into it. ive found prices for just the two, but i read somewhere thay you need all new mounting brackets and stuff for the hood and after all said an done around 2 grand in just parts. im gonna keep looking into it tho
#1872
#1873
The resolution on that image is too low to upscale it to a size that would be suitable to be used to create a decal. There are only a certain number of pixels in that image and to upscale it would look crappy. Essentially you can't create new pixels on upscaling. You will need a much higher resolution image to achieve the quality at the final size of the decal. But I did up a photoshop that shows what the decal would look like on your truck.
