Photoshop Thread 1.0
#752
With that being said, I set out and created a super clean sport truck, black gloss headlights with clear reflectors for that crisp look on a white truck, blackout grille with a black chrome grille surround and blackout fogs to match the headlights, black badges with white overlays, a bit of black out back with dark tails, and PTM handles and mirror caps as well as bumpers.
Then i slammed it down on some NBS king ranch painted wheels, a nice dark gunmetal/black color in a 22 size.
Not what you wanted so i took that recipe and turned it around,
same mods, just a 2inch level all around with some 33 BFGs since you didnt specify (IDK jack squat about offroad tires anymore or whats "cool" or "in" and bfgs were always my fav when i had a lifted truck over 12 yrs ago)
Stock 18s with a satin black coat, caps still chrome but the beige PTM white on the center.
Cause thats how i would roll
but come on you know you like the first one more
#754
I'll try this thread out, had watson on here try to do this a little while back. did a decent job but its difficult to see the body lines because I asked for black.
can someone try it again and try to make the body lines more visible? maybe ligthen them up? the body line that flow up with the grille between the insert and headlight. kinda like the picture i'll supply last, but want some red on the very outer portion of the hood.
Hood
probably the best angle for the truck to 'shop
watsons job (thanks again, probably should've asked you to lighten the body lines a little)
http://www.screen-fx.net/upload/KlitchChop2.jpg
Hood
#756
Hood
Hood
#757
Or at least a picture of the whole hood.
EDIT:
Eh, decided to give it a try, though I'm kinnda confused as to what you want?
#758
I've quizzed them for better pictures and not received them. they claim thats the only set of pictures they offer, nobody has supplied them a installed photo.
I'm not sure how to make it more clear, but i'll try again.
theres 4 heights, 3 body lined on the new hood.
one of these lines coincides with the oem hood, which also follows the contour of the grille surround, this happens to be the furthest outset body line and the lowest hood height up to the next highest hood height. elvato's rendition somewhat follows the body line im referring to, kinda looks good.
#759
Ok, that's kinnda what I thought you meant. When I copied the hood, I didn't copy the outside "panel" since I figured you wanted it red, so I'd just keep the stock red. The only problem was that a) I'm guess you want it gloss black, and b) because of the angle of the picture of the hood, I couldn't "stretch" the hood to fit the line, or else it started looking weird.
I guess I could close a bit of it to make up the body line. Also, I didn't know if you wanted the bug guard or not? I'm guess you're taking it off when you put the hood on?
#762
yeah, I tried doing a gloss black and I couldnt find the body lines after I did that, I figured after I tried my hand at skewing the hood the angles werent close enough for me at the very least.
I'd read this: https://www.f150online.com/forums/ap...od-review.html
#764
wondering if I could get one of your guys to shop this one to show me what it would look like if I dropped the back side to match the front, and what it would look like if I leveled the front
eta: also wondering what it would look like if I painted the wheels white
would this pic work, or do you need something better?
#765
Front
Rear
id do front since you have the replacement bumpers
did a special mod
