Photoshop Thread 1.0
#767
#769
#772
#774
again thanks a lot..
#775
How big/heavy is your boat?? I would think you should be okay towing your boat, but it will decrease your towing capacity...that said, you can gain alot of it back with rear airbags. I think firestone makes a kit and many others - that's just the only one I can think of off hand. You can look up a drop kit for your truck. Find one from a reputable brand like Eibach, Belltech, Ground Force, etc. and everything should be included. I'm not sure how much different the suspension is on the newer trucks, so I won't specify the different parts needed. In the rear you can use drop shackles and drop hangars for 4-5" of drop. And some pinion shims to fix the angle of the driveshaft.
#777
#779
