DDM Single Beam HID Installation Need Help!
Old 01-22-2010, 08:56 PM
expedition4x4's Avatar
i need help installing my single beam HIDs are numbers 1,2, and 3 connected correctly? i tried reading the DDM instructions but they didn't help AT ALL! my question is does the circled part (number 4) plug into my factory bulb connector? or is there more that has to be done
Current Way Connected
How It Came from DDM
Old 01-22-2010, 09:26 PM
ELVATO's Avatar
Yes, it looks like that is how it should go. Weird how your bulb has the connector circled in number 4, where as a lot of the other DDM bulbs have only prongs (basically the metal spades inside the connector.)
Old 01-22-2010, 09:29 PM
well i tried it that way this afternoon and no dice they didn't light up, but i have another solution what was on DDM site that might work
yes i too thought that it wouldn't have the connector, and believe it or not i think my kits might be used!?!?! the ballast have some scratches on them
Old 01-22-2010, 09:36 PM
ELVATO's Avatar
You're putting the headlights on ON and not on Auto, right?
Can you hear the ballasts "humming" at all?
Also, I'm guessing you're not using a relay?
Old 01-22-2010, 10:27 PM
yes im putting them on "ON"
no i dont hear any humming
nope no relay just the stuff ddm sent me
and i just tried (like it said on the ddm site) plugging piece 1 from the ballast into the OEM connector, 2 and 3 into the same location and leaving piece 4 and piece 1 from the bulb disconnected and it didn't work, i even tried both ballasts and no dice
Old 01-22-2010, 10:34 PM
ELVATO's Avatar
Yea, 1 and 4 are basically just an extension. You might have better luck with a relay. A friend of a friend, who owns a shop and sells HID kits, said that Expeditions are sometimes finicky, and require a relay. Me thinks that there is a possibility that your ballasts are bad.
Should have went with VVME
Have you also tried flipping the socket when you plug it in? The wiring might be reversed?
Old 01-22-2010, 10:39 PM
i have one relay i'll try it out to see how it goes, and your right it might be flipped! i just opened up the package that had the HID kit for the fogs and it has the exposed wires!!!
Old 01-22-2010, 11:06 PM
dirtyd88's Avatar
Go grab some 9145 connectors from autozone and slice them into the bare wire. That's what I'm going to do.
Old 01-22-2010, 11:21 PM
Old 01-23-2010, 11:36 AM
dirtyd88's Avatar
Looks good! What did you finally end up doing to make it work?
Old 01-23-2010, 04:49 PM
ELVATO's Avatar
Hopefully that's just a misaligned headlight and not an oncoming driver's point of view. I thought you said you were going to get 5000k?
Old 01-23-2010, 05:50 PM
that is 5000k?
Old 01-23-2010, 06:34 PM
ELVATO's Avatar
Really? Didn't know there was that big a difference between 4300k and 5000k.
That is with the high beams on (have Ultras in there.) You can see the color difference.
How is your cutoff?
Mines not bad compared to stock:
Old 01-23-2010, 10:40 PM
i think i might need to adjust mine? what do you guys think? i drove around like that and no one has flashed me, i still need to install the the kit for the fog lights tomorrow, and then later this week i'll install the high beam kit when it gets here, anyways on to the pics
Old 01-24-2010, 12:25 AM
dirtyd88's Avatar
They 35W 5000K has a bit more blue than some would think. I know first hand. Also, unless you can control exposure on you camera, or FPS, it always shows up a little bluer than real life.
Lights look good man!
Quick Reply: DDM Single Beam HID Installation Need Help!
