DDM Tuning hid kit
Old 05-18-2010, 11:48 AM
ELVATO's Avatar
If it's bi-xenon, yes, it should come with a harness. For the fogs, you technically don't need one, but I would get it regardless. Not sure which kits from DDM they are, but some of them don't come with female connectors to connect to the OEM connectors. They come with spades instead, which you could either tape into the OEM connector, or cut off and splice with the OEM connector. If you get the harness, you could splice the spades into that, instead of splicing into the OEM connector...
I mean, I guess you could also technically just connect the OEM connector directly to the ballast, though you'd have the mount the ballast closer to the connector.
Plus, it's generally a good idea to use a relay whenever possible.
Old 05-19-2010, 09:21 AM
mgp32's Avatar
The relay would be included with the kit correct?
Old 05-19-2010, 12:07 PM
ELVATO's Avatar
Bi-xenon yes
fog (or most any single beam kit) no (you have to purchase separately)
Old 05-19-2010, 04:26 PM
djquik1's Avatar
Originally Posted by mgp32
When you buy a bi-xenon kit from DDM tuning does it come with a harness to wire directly to your battery, or do you have to order that seperately? Also, I want to get fogs as well, from what I read it seems I DO NOT need a seperate harness for them ,correct?
The bi-xenon does not come with the relay harness from DDM.It comes with the controller harness that switches the bulbs from low/high only.
Old 05-19-2010, 05:46 PM
RiverRacerX's Avatar
I just got my DDM single beam Raptor kit last week and it didn't come with a harness, just the spade connectors. I didn't want to splice my OEM wiring (cheesy) so I ordered this:
http://www.eautoworks.com//product-e...com-183999.htm
Coming today, so hopefully it will fix my problem.
Old 05-19-2010, 06:33 PM
sam1947's Avatar
I don't think this is what you want..you need this complete harness: http://cgi.ebay.com/ebaymotors/H13-9...Q5fAccessories For the Headlights. The harness for the fog lamps would be this one: http://cgi.ebay.com/ebaymotors/H10-9...Q5fAccessories
Old 05-19-2010, 08:23 PM
ELVATO's Avatar
I think the control harness functions as a relay, since you have to connect it to the battery...
As far as harnesses, if they cost the same, it's better to get the relay. Instead of splicing into the OEM wires, just splice into the relay wires.
Old 05-20-2010, 10:51 AM
luner99's Avatar
I am looking to order my HID kits today for my heads and fogs and I have a question... The harness that everyone is talking about - it sounds like it is wired directly to the battery but is it still switched with the "headlight switch" or the "auto sensor" like our normal heads? I have never had HID's but want them so any clarification would greatly help me.
Thanks!
Old 05-20-2010, 03:10 PM
ELVATO's Avatar
Yes, though it's not a good idea to use the auto lamps when you have HIDs. If it's dark outside, the lamps come on as soon as you put the key in the ON position, so the HIDs would turn on for half a second, turn off when cranking, then turn back on -> not good for the bulbs (they need to be on for at least a minute.)
Old 05-21-2010, 06:33 PM
I am installing mine tomorrow. I will do a write up with photos. Maybe even a YouTube vid?
Old 05-26-2010, 04:46 AM
gabe907's Avatar
Neither lights turn on, DDM Tuning
2006 F150 XLT Supercrew. H13 bulb.
I just ordered some 10,000k HID Bi-Xenon High/Low with the harness kit from DDM Tuning.
I installed it, I checked for reverse polarity but no.. And the problem is, neither of my lights are coming on, but my fogs and parking lots will come on. What should i do?
Old 05-26-2010, 10:42 AM
ELVATO's Avatar
Check the 2 circled items to see if you're getting voltage. If not, check grounds. If not, the relay module might be bad. Another possibility is that the H13 female connector is wired wrong.
You can check the ballasts by hooking the female of the circled connectors up to your fog lights.
Quick Reply: DDM Tuning hid kit
