Stainless Cleaner
#31
Stinless Steel
I have a stainless steel exhaust square tip infront of the right back tire. It seems to get alot of mudd and crap on it. I started to notice some surface rust. I know this one sounds out there and I doubt many have tried it but once you do you will never change. If you have a buffer (high speed) get some jewler rouge(like a hard clay) you hit the rouge with your pad and get a litte on it and hit that stainlees. You buff until it turns black. once it does wipe away. You will be impressed very effortless. It also puts a water proff coat on the surface. Try it and give some feed back. Sometimes it is hard to find the rouge (any jewlers store will have it.) I think it is like 2bucks for the bar and it will last years! GOOD LUCK
