Arghhh! Deck and fence stain on paint! HELP!!!!
I was spraying fence stain on a fence a couple of weeks ago. The wind was blowing and swirling around a bit. Being an idiot my truck was parked in the driveway. Needless to say it now has tiny little cedar orange tint specs all over it.
I have washed it several times and today attempted to use a claybar to remove the tint specs. I bought a Meguiar's claybar and their final detailer to lubricate the bar. It didn't even start to remove the specs.
Any ideas on removing this? It looks like paint overspray. What can I use to remove this without harming the paint?
To let you know what I tried today, I hand washed the truck using dawn dishwashing liquid. After I dried the truck I attempted to use the claybar to remove the specs. I tried it on the painted surface of the side mirror, the plastic trim around the windows and on a side window to no avail.
Thanks in advance.
Thanks in advance.
They are bigger than fine overspray.
Thanks for the input. I worked on it some more and the clay will remove them but it takes about 1 minute of rubbing with the clay to clean just one little spot. It would take days to do the whole truck with the clay bar.
I will try the mineral spirits to see how that works. I didn't know which products you could use that would not hurt the paint.
Guess the clay bar will get used on my wife's Jetta. My truck is too new to need it right now.
Thanks again,
Greg
Thanks again,
Greg
