Mike's "alternative ways" of stripping wax
Intel,
Yep, I've heard the same thing. Some people have said that using Z7, and Z6 is all they need to keep their vehicle nice without waxing or applying sealants. However, I've found, if Z7 does leave some Z2 behind........... it's not much. As a matter of fact, if you "over-dose" the Z7, it tends to dull up the finish a bit.
Originally posted by Boss_429
Intel,
Intel,
chknbone,
Removing paint sealants just as you mentioned are alittle tougher because of the tough barrier they form to protect the paint, hence harder to remove than wax.
There is a couple ways you can go about this. A.) Acid Bath - Pro makes an Acidic Bath (C-45) you can use on your paints surface. This will strip sealants and anything else on there very effectively. Intel used it on his truck, and came back with a great review about it. He posted the results about it but that's like an ancient thread now, lol B.) Just let if wear off - Anything beyond 6-8 months is about when I would say the sealant is getting weak. It's still there but for not much longer. To ensure the sealant is fully worn off your paints surface, don't do anything with it for a full year. This will give the sealant ample time to wear off. C.) Compounding or some good heavy duty polishing will strip the sealant too as well. I don't see the point in removing paint just to remove a protective barrier, but that's just me.
Most people think that Dawn will remove the sealant. I have proved myself that sealants laugh at Dawn. Put it this way, IMHO, If you don't like the sealant that you have on currently, and you don't have the right stuff to strip it properly, they can be like terds that don't flush ya know, LOL! I couldn't resist. Good Luck,,,,91
Is it just me, or what? I've never had to remove old wax, nor have I ever felt compelled to. Then again, I only wax my vehicles twice a year. Maybe I'm not as picky as some of you about having 'the best' shine. A 'good' shine is good enough for me, and I've had few paint issues through the years.
Years...I mean years ago, my grandmother would was her car with Comet. After a while, that car had 'flat blue' paint! She never waxed it, just washed it with Comet. My grandfather (on the other side of the family) would always put a little kerosene in the wash water. He never waxed either, but his car always shined.
