Rust Proofing Undercoat
Any ideas for products for a undercoating a new 2003 F150. From what I have learned, the fine particle wax products are the best for penetration and self healing. You have to use the amber colored ones because the black ones add carbon black which foul the aerosal tips. I guess if you used your own spray equipment you could use the black.
The asphalt type tars, or the rubberized undercoatings are good at sound deadening and good at corrosion protection except where cuts or tears may appear in which case moisture could be trapped between the metal and the undercoating accelerating rust and corrosion.
Are there any national chains that exist anymore that do undercoating, any idea what they use. Recommendations.
Do any of those rust proofing francises still exist, like Ziebart? Anyone have any products to recommend. Any comments on the use of ultafine wax versus the asphalts. I have read that the waxes are better for the long term as they have healing ability around scratches and water doesn't get under them.
The trend in this area (Buffalo, N.Y. seems to be an oil type substance that you have sprayed on once a year and costs about $100.00.
My brother has used this for a number of years on his 91 F150 and swears by it. I had it done to my 2000 Lariat which I bought last year.
I talked to the guy at my Ford Dealer who sells the traditional under coat and he said that he thought that the oil stuff was more effective.
If you are interested at all, let me know and I'll get you the info on it. Bruce Chamberlin
found these products
http://www.waxoyl.com/en/produkte/hardwax.htm
There is one company locally that uses this product. Its a hard wax.
There is another company that used an asphalt product, but claims to be very good at preping the truck, masking tape, etc. He swears by the asphalt and that only thing that will hold up to abrasion, and says that 'Rusty Jones used to use a wax product and now they are out of business".
Any recommendations
Any recommendations
