Question about Chevron Techron.
I just bought a bottle of Techron. And I need to know, is an oil change recommended after using this stuff? I'm weary about doing it right now if I have to change my oil afterwards. I just changed my oil about 1500 miles ago, and I don't want to have to change it again, just because I used Techron. Is it better to wait until it's about time to change my oil before I use this stuff? Any help is appreciated. Thanks.
If it is just a fuel additive to clean the injectors then no you do not need to change oil after. Every time I change my oil at 3,000 miles I always put a bottle of Valvoline injector cleaner in. I asked both Ford dealers service departments in my area the same question. They both told me there is no need to change the oil and that it is indeed good to put a bottle of injector cleaner in with every oil change.
However, for you're own piece of mind call your dealer and ask them...
Yeah, it's just a fuel additive that your'e supposed to pour in your gas tank. Since it doesn't say on the bottle that I NEED to change my oil afterwards, I assume it's ok. If I'm not mistaken, I used a bottle of that stuff last year and didn't change my oil. So it should be ok. Thanks 01.
That's good news. I don't see how it could get in the oil anyways because Techron is highly flammable. And it will just burn up in the combustion chamber. And I don't think carbon deposits can get in the oil because it can't get past the piston rings. Most likely, the carbon deposits will blow out the exhaust. That's just my theory.
