Paint Prep Question
Paint Prep Question
After a lot of research and thought, I've finally decided to try Platinum products (Paint Cleaner and UPP) on one of my vehicles to see how this stuff works. I have two questions though before embarking down this road.
-1- I have some swirl marks / fine scratches to contend with, and I've heard the Platinum Paint Cleaner won't address them very well. What should I use in conjunction with (i.e. before) the Platinum Paint Cleaner to get rid of the swirls? Can I use a product like Meguiars # 9? Any comments on how to use it along with the Platinum products?
-2- Will I benefit significantly from waiting 24 hours and applying a second coat of UPP or is the 2nd coat unnecessary?
Let me know as I want to try this stuff on Monday.
-Mike-
-Mike-
Big Deal,
Keep in mind that UPP is a sealant that needs a clean surface free of any oils, waxes or other residue that aren't compatible with the UPP. If you use the #9, you would want to follow it with a light cleaning with the UPC prior to the UPP. A lot of people have had great luck using #9, then Klasse AIO, and then UPP. I plan on trying Poorboys Pro Polish, followed by UPP, as the Pro Polish is a pure water based polish that should allow the UPP to bond and cure.
I think you WILL benefit from letting the UPP sit............ at least overnight. The polymers need time to cure. I've found that the UPP looks better a day or two after letting it sit anyway.
One last thing, as with all sealants, a thin coat is far better than a heavy coat, and makes the product easier to apply and remove. Also, let the UPP sit on there for about an hour before removing.
Hope this helps, and let me know if you need more info, or have any other questions.
Originally posted by Boss_429
Big Deal,
Big Deal,
Please comment on this polish/sealant process, as this is the process I was thinking of using.
1st - Meguiar's # 9 (DA applied)
2nd - Platinum UPC (DA Applied)
3rd - Platinum UPP (Hand Applied - One coat only)
-Mike-
Big Deal,
The Poorboys Pro Polish will address minor swirls and oxidation. If the swirls are nasty, he has 3 different levels of more aggressive Polish......... SSR1, SSR2, and SSR3 to handle just about anything, and they are all water based, so they should work with any sealant.
As for your 3 step process............. I think it will be fine, as long as the #9 removes the swirls. If not, and you want to stick with Meguiar's stuff, you could DACP, followed by #9 for the swirls.
Good luck, and let us know how it turns out!
Big Deal,
Big Deal,
Sorry for all the questions, but this sealant stuff is definitely new territory for me.
A final thought. How long have you gotten between UPP jobs (i.e. durability of finish).
-Mike-
Big Deal,
No problem, glad to help.
I don't think you'll need the UPC after the Poorboy's Pro Polish, as it is a pure polish (no oils, waxes, or silicones), and it's water based. So, I would put the UPP on right after the Pro Polish. My only concern would be whether the Pro Polish will get out all your swirls. Of course, I would have the same concern with #9. You want to get the swirls out as best as possible, as the UPP is very optically clear, and will show the imperfections.
As for the durability of the UPP, it's hard to say. I have 2 coats on the roof of my F-150 since the end of April, and I think it's starting to lose it's stuff. So, that's around 3 months, which is better than just about any carnauba.
Good luck.
Good luck.
BigDeal,
Any feedback here? How did you make out?
BigDeal,
I'll update you with some thoughts / comments when I get the Platinum stuff on the car.
Thanks again for all your feedback.
-Mike-
