Replacing Tail lights
Drop down the tailgate.
There are two bolts you remove from the inside of the bed.
Once those are removed, there are two tabs you need to press in for the assembly to come out...
You know what to do from there.
Or if you want, you can get images from your owner's manual.
If you dont have that, http://myford.fordvehicles.com - register and you can get a bunch of stuff specific to your truck, including the owner's manual with images and everything (in .pdf).
