Sideswiped my truck
Sideswiped my truck
Can anyone recommend a good paint remover or product for removing a small amount of paint I got on my '97 F150 when I lightly sideswiped a Cherokee in a crowded parking lot yesterday? The goods new is that no body damage occurred, just a few streaks of the other vehicles paint on the lower passenger side. Thanks.
Body scrub is a pretty good product as I've seen a before and after on a buddy's vehicle at work.
Rubbing compound would be down my list as first choices but, it would probably work. I think you'd have quite a bit of 'clean up' work after using something as abrasive as RC. I'd almost use 3000 grit before RC... that's just me though.
AWH,
I just had to remove some paint off of the side of my truck from when I lightly grazed a friends car in my driveway. I touched it just enough to swap paint but not really scratch it or dent the metal. I used Meguiar's Medallion Preminum Paint Cleaner and it cleaned everything right off. It will remove any polish and wax you had on as well so expect to re-apply that stuff after using the cleaner.
chknbone
chknbone
When I had my '98, someone in a red car scuffed my door with their bumper (I guess it was their bumper). I left it alone for a while because I didn't know what to use to get the paint off.
When I took my truck in to get the bed sprayed with line-x, the guy prepping the bed saw the scuff and used the alcohol he was prepping the bed with to remove the paint from the door. I worked great!
All it took was a little wax to get the scuff on the door off.
![rocker](https://www.f150online.com/forums/images/smilies/rocker.gif)
Good news Jello--since Goo Gone is citrus based it is harmless to your paint. However, I would wash it off as soon as it had removed whatever it is you're removing. On the other hand, Goof Off WILL damage paint. It is solvent based. I used it to remove the ARE badge glue off of my old camper shell on my 98. I only kept it on for a few minutes and I could tell it was going to work on the finish. A couple of coats of Mequiars did the trick though.
