Heavy Oxidation
on
Originally posted by rrroscoe
I've got the scratch-X, it helped a little. When I did a patch, and compared it to an undone area, I could see the difference, but when the whole thing was done, it looked like I never did anything.
I've got a buffer, and even tried polishing compound-no good!
I know my Cyclo has the normal pad for polish, glaze and wax, and then there is a green de-ox pad, which is much more agressive.
I guess it depends also on what type of buffer you have. If it is a PC, DeWalt or Cyclo, you should be good to go with a compunding pad, or de-ox pad and polishing compound. If it is the normal 9 to 11" buffer from the auto parts store, it might not have enough umph to get the job done.
Just some thoughts on the topic....
rrroscoe,
Good thing you brought this one to the top, I missed it.
First, without seeing the oxidation, it's tough to recommend products. However, being that oxidation is generally dried out, dull paint, I would do as follows:
Get yourself a good paint cleaner like Medallion Premium Paint Cleaner, Poorboy's Pro Polish, Deep Crystal Paint Cleaner, or something similar. Then get yourself several applicators, and plenty of good towels. Next, apply the paint cleaner by hand, changing the applicators and towels frequently. On badly oxidized finishes, you sometimes need to do more than one applicaton of the paint cleaner.
A lot of people might recommend going right to a product like DACP (Meguiar's Dual Action Cleaner Polish) using a buffer (rotary or orbital) and a pretty aggressive pad. However, I don't like clogging my pads up with "crap" like oxidation when using polishes. I like my polishes to do just that........... polish! Let the pure paint cleaners do most of the "cleaning"!
Anyhow, once you've done the paint cleaner by hand, you'll need to judge the paint surface. If it's still pretty dull, that may be the time to get out the DACP, and a polishing pad for your orbital.
If the paint looks pretty good after the cleaning, or after DACP, you could go right to a product like Meguiar's #9 or Poorboy's SSR1................. then maybe #7......... then your wax. All depends on how far, and how much you want to put into the "beater"?
Another quick way out after the paint cleaner would be to apply a cleaner wax like Meguiar's Cleaner Wax, Mothers cleaner wax, Klasse AIO............ or one of several other good Cleaner/Waxes using your buffer and a polishing, or finishing pad. These "All-in-One" products can sometime add just that little bit extra cleaning you need, and still add a nice shine.
Hope this helps, and good luck!
I've been outta detailing for about 7 months so I might be a little rusty but...
Paint Cleaners as basically compounds. There's not too much of a difference. If you are doing this by hand, then you can use a more agressive product to remove the oxidation. Cotton towels or cotton applicators (sponges witha cotton cover) work best by hand for removing heavy oxidation. They have a lot more room for the removed oxidation to go and the agressiveness of the applicator also helps. Some stuff I like is PRO's DUZ-All, Meguiar's DACP, and 3m's Rubbing Compound.
You'll have to use a polish them to get the final shine and remove any haze from the paint from the compound. Meguiar's #9 and PRO's Swirl Elimnator and Polish work well. Use a foam applicator for the final polish.
