How long can you leave Zaino on before buffing off?
Well I got some zaino and decided today would be my first attempt with it and did the following:
Wash with dawn
Claybar
Wash with zaino wash
dry
Guess this ended up taking a little longer than planned cause I got two coats on and it was starting to get dark so I put a third on since I still had some mixed up with the ZFX.
My question is since the temps are starting to drop some (still 65) and it might take a little longer to dry, is there any reason that it can not be left on over night and buffed off in the morning.
Guess if I dont hear anything I will go back out in an hour or so and try to get it off as best as possible with the crappy lighting I have.
Also, I got three coats out of one ounce of Z2....am I putting it on to light or will it still work fine?
Thanks!!!
Wash with dawn
Claybar
dry
Thanks!!!
You can leave it on as long as you like. It will not hurt anything. Overnight should be fine, any longer then I would be cautious as to dust starting to build up and then buffing off the Zaino with dust on it could possible cause micro scratches.
However, if it is in a garage you should have nothing to worry about. 3 coats out of an ounce is great. The key is putting it on real light as it makes it much easier to buff off.
