Washer fluid resevoir keeps freezing!
Whenever the temp drops to about 20F or lower, my washer fluid will not work. Anyone from a snowy area knows what it's like a few days after a storm, with all the gunk they spray on the highways...you need your washers every damn 5 minutes, if not sooner. I assumed moisture from snow was icing up the nozzles. Today I looked under the hood, and the washer fluid was like a blueberry slushie! I thought washer fluids were all generally good to -25C or so. I nose the truck up close to my garage, so the front corner is protected from the wind. The fluid in there right now is from my Ford dealer. I had a 4X4 T-case problem and while it was there they topped it off.
Anybody reccomend any hight-test washer fluids?
