Porter Cable 7424 Dual Action Polisher
#32
I have ordered ..........
The 7424 PC which will be here on Tuesday. The Mequiars kit arrived today.
I was going try puting on zaino with it. I have been a Z freak for about a year and a half. I just wanted to speed up the operation.
So, once it is on, can I take it off with the buffer too (without using a towel under it)?
AND What about using microfiber towels to remove the zaino or other waxes (natural or synthetics)?
Are the MF towels too aggressive for the job? Maybe they would take off too much of what I am trying to put on.
Thanks,
Tom
Thanks,
Tom
#33
#34
You can get a MF bonnet to fit the foam pads that fit the PC from mecguiars. Place a pad on you PC, slip the MF bonnet on the pad and get after it. I will usually go through 4 bonnets buffing a vehicle. Throw'em in the washer, dry them, and they will be ready for their next assignment.
Two things. First this assumes you are removing a thin coat of product. If the product has been applied too thick then a terry bonnet works better. Second, start off with the PC set on a low speed until you get use to it taking off product.
Screwdrive
Screwdrive
#35
