Bird Poop
Bird Poop
SO does anyone know how to remove bird poop from the paint? I washed the truck and you can still see where the damn bird dropped anchor on it. (I think it ate a bad burrito or something)
It's almost like a waxy residue on the paint and it won't wash off.
any suggestions/idea. (besides pulling out the 22 and start pegging them off)
RP
I'd agree with RP in that the damage is already done. Your big challenge now is not to make the cure worse than the original problem. What you probably have is some minor clear coat damage. Depending on how deep the damage goes, you might be able to buff it out. I wouldn't recommend using a buffer unless you really know what you're doing though. You can buff right through the damaged area, the clear coat and the color coat so fast it will make your head spin. Then you have a real ugly problem.
I'd suggest starting with some fairly non aggressive stuff applied carefully by hand first, then see what's happening. You can always work up to a harsher compound if you're not seeing results. It's much harder to undo damage caused by starting too aggressively. I'm sure RockPick can recommend some good products to try - and the correct order. Good luck!
