Thinking about getting a PC 7424
Originally posted by gmorf33
Alright.. looks like i've decided on SSR #2.5 then, then i'll follow that up with #9 since I already bought it. Then the Klasse AIO, NXT, and #26.. this is going to be a long process, but should be fun to see the results. My dad's truck will actually look good again
Option #1: Apply SSR #2.5 then Klasse AIO, or
Option #2: Apply SSR #2.5, then NXT and a topper of #26
I'd be reluctant to apply #9 under Klasse due to the additives in #9. I also would see no benefit whatsoever in applying NXT over Klasse. I think that would be an unnecessary step. After you use the SSR #2.5 polish, if you opt for Option # 2, I doubt you'll need to apply #9 either. SSR #2.5 'should' address your swirl/scratch issues.
Good luck on your truck.
RP,
I believe BigDeal was pointing out that #9 does have considerable oils/fillers that it leaves behind. Both Klasse and Zaino really work best when then are applied to previous layers of Klasse or Zaino, or to a clean paint surface free of all oils, silicones, solvent and what have you. Poorboy's polishes do not contain any oils, silicones, or fillers that might inhibit the bond of Klasse (or Zaino). Still, I recommend that even with Poorboy's polishes, a silcone free QD, or a product like Spray & Wipe should be used to lightly go over the paint surface before applying Klasse. This insures that any solvents or dusting left behind is removed.
Originally posted by RockPick
Huh? More specificity please.
