Mr. Clean Magic Eraser + 04 F150 Door handles = F$%#!!!
Old 10-09-2004, 11:43 AM
TonyPTX's Avatar
crap....that sucks....
planning man...where was the planning?
  #77
Old 10-09-2004, 12:32 PM
98SCREAMER's Avatar
Location: Houston, by way of every major city in America.
Exclamation
Yep, called blushing. It happens when there's too much moisture in the air. One thing that helps, not that it would now, is to bring them inside immediately after painting, and hitting it with a hairdryer. It may still clear up if you're lucky though, give it a little more time to dry, inside the house preferably.,,,98
Good luck
  #78
Old 10-09-2004, 08:01 PM
dzervit's Avatar
The plan was to be able to use the single can for all 5 handles. They (paintscratch.com) said the large spray can would cover about 6sq ft. BS! That tossed the plan into a tizzy. I knew I'd be low, but thought for sure I'd be OK for these two friggen' handles. What a huge downer.
Now I have to drive around with my blue-tape of shame covering my doors, and no interior trim w/ rattles galore from the rear door.
*SIGH* Please hurry with my paint, paintscratch.com!!!!
So, next weekend isn't going to be as warm... prolly barely hit the low 60s... what am I to do?! No place to paint indoors... they say paint around 70... why? I understand how humidity effects the process, but will the 10-15 degree lower temps create more issues for me?!
  #79
Old 10-09-2004, 09:13 PM
98SCREAMER's Avatar
Thumbs up
Temp won't affect much, other than drying time. Humidity hurts drying time somewhat, but also creates the blush effect. Cool and dry would be your best bet, since it probably won't be getting any warmer up there.,,,,98
You can paint and then pull them inside the house immediately, that should reduce the blushing...
  #80
Old 10-09-2004, 09:31 PM
dzervit's Avatar
Thanks for the tips, 98. Last ? - How high is to high for humidity? 50%? 40%? 60%? I guesstimate it was in the 50-60% range last night...
  #81
Old 10-09-2004, 09:42 PM
98SCREAMER's Avatar
Thumbs up
I would imagine 60% or higher. Cold makes the effect worse for painting. Cold and dry is good, cold and wet is bad. When the sky clears up after a cold front, is usually a good time to spray if you don't have access to a heated area. Any one you know have one of those kerosene heaters you can borrow? Pull the truck out, close the garage door, and fire it up, hehe. ,,,,98
  #82
Old 10-09-2004, 09:45 PM
dzervit's Avatar
mmmmm... paint fumes & kerosene. I can hardly wait.
  #83
Old 10-09-2004, 10:24 PM
98SCREAMER's Avatar
Thumbs up
Well, might leave the door open a few inches. Don't want to pass out, lol!,,,,98
  #84
Old 10-10-2004, 03:05 PM
dzervit's Avatar
I've got two handles left to test on without fear... check out my profile & shoot me an e-mail. I'll reply with an e-mail with my mailing address. And provide some honest feedback for 'ya.
  #85
Old 10-12-2004, 09:19 PM
DrPaul84's Avatar
you should be nice to the rest of us and take pictures of your door panels all apart, i would be interested in painting my handles an stuff, but fear taking the truck apart...
  #86
Old 10-12-2004, 11:09 PM
dzervit's Avatar
Dr, have no fear taking the doors apart. They were some of the easiest doors to rip apart. No real nasty clips or anything. Screws and that's about it. I'll take some pics on the drivers side process.
I've also decided to get some dynamat xtreme and some dynashield to spray on the outer shell. Then, the rear wall, headliner and floor will follow. I'm going to see if I can achieve a Lexus-quiet F-150. I'll bust out the spl meter and take some measurements. Should be interesting.
  #87
Old 10-13-2004, 07:46 AM
JohnAndDar's Avatar
Hey, what happened to dzervit's original first post in this thread. I just opened the thread and my reply to d's original post is showing up as the first post...
Rockpick, any ideas?
~John
  #88
Old 10-13-2004, 08:27 AM
dzervit's Avatar
AAAHHHH!!! I'm slowly being erased!!!
  #89
Old 10-13-2004, 08:30 AM
98SCREAMER's Avatar
Wink
Man that Magic eraser is one powerful product!?!?! NO WAY I'd use it. It's even covering
up it's own damage evidence,,,,98
  #90
Old 10-13-2004, 09:24 AM
TonyPTX's Avatar
I think it's D's sig file/picture sucking up all the alloted space for a thread....
Tony
Quick Reply: Mr. Clean Magic Eraser + 04 F150 Door handles = F$%#!!!
