calling out the pro's!
It's far from an angle grinder like Matt mentioned.... It's a dual-action polisher. That means that it has two motions of movement; one circular, another up and down. This, in turn, makes it difficult for someone to really screw up their paint. It's somewhat failproof.
As for the ones that are sold at Wal-mart and similar, from my experience, I've only seen what is known as Orbital polishers there. These are still commonly used in the detailing industry but, honestly, outside of that, i don't know a heck of a lot about orbitals. My hunch is that the units sold at WallyWorld for very little money are okay for a very occasional use but, outside of that, I bet they're pretty low quality. But, like i said, I have no experience with a Wal-Mart orbital...
My next power goody might be a Cyclo Polisher... I have a used one on the line fairly cheap... Still not sure if I want to go that route though...
RP
RP
Originally posted by Willie Dynomite
i thought that's was orbital meant. up and down and all around! so what's the diff?
Rotary Polisher (AKA:Rotary): Spins in circles and is VERY powerful. Should only be used by someone who is trained on the machine as it can cause VERY serious damage to paint in the wrong hands.
Orbital Polisher (AKA: Orbital): Spins in circles however; doesn't have the 'oompah' that a Rotary brings to the table. This unit, as I'm told, is much more user friendly but still poses the risk of causing swirls and such if not used correctly.
Cyclo Polisher: (AKA: Cyclo) is a dual-head pnuematic tool that was originally used to polish airplanes I'm told. It's used in the detailing industry frequently but, beyond that, not used much anymore. This, again, should only be used by a trained professional as it can inflict some serious problems in the wrong hands.
All four of these products can cause problems if you're being careless and, as I mentioned, a rotary probably isn't anywhere near what you're wanting as it is a VERY powerful tool that can thrash paint in short order when in the wrong hands. Overall, the PC (short for Porter Cable 7424 or 7336) is probably the best and safest method. While the product can remove most surface blemishes, it isn't a rotary and shouldn't be treated as such.
RP
