Interior Plastic Cleaner
If you ever get marks on your interior trimwork that seem to be difficult to get out, one thing I've used with great success is a toothbrush dipped in warm water and a small amount of Crest "Extra Whitening" toothpaste.
This product has a slight amount of grit to it that dissolves very quickly when used. It seems to be just aggressive enough to get out stubborn marks, without being so abrasive that it damages the plastic and/or vinyl trim material.
How bad is the grime?
If it's a very light grime, I would recommend simple hot water and a 100% cotton-terry high-pile cloth.
If it's a bit more ground in, there is a suite of products that can be used and be effective in removing the problem areas.
I might follow with an interior detailing spray or 'matte-look' dressing as well.
RP
RP
Re: Interior Plastic Cleaner
Originally posted by Bugman
Hello,
What can I use to clean the dash, door panels and all other interior items in my 2005 Lariat?? Thanks. Bugman.
Hello,
http://www.midwayautosupply.com/deta...ption.asp?9204
Thanks guys,
I was looking for a cleaner or anyway to clean my interior door panels and other interior parts on my truck. I have been getting alot of road salt and mud on my door panels mainly from my three kids and myself. I will try some of the cleaners that were mention. Thanks again. Also, has anyone here tried to clay bar their black truck?? I'm thinking about using the clay bar this spring but, I'm concerned about scratches in the clear finish. Any thoughts??
RP
Originally posted by Truck of Doom
All the rubbery parts on my FX4 seem to have a tacky feel to them. Is this normal? I need to clean the inside of my truck. Will a towel with hot water remove this feeling?
That and other, silicone based "protectants" will do that to the rubber parts. It acctually breaks down the rubber.
I did that once years ago and the only thing that got rid of the tacky feeling was TIME. As I remember it took nearly a month.
Enjoy the feeling while it lasts.
Doug
