Tire Cleaning
My personal favorite is Meguiar's Citri-Gel and a nylon bristled brush.
Be careful with just about any chemical that you utilize on your tires. Most of the chemicals on the market (Westley's BleachWhite (which I think is a fine product), degreasers, etc...) aren't designed for use on your wheels and the overspray or run off from your tires can, potentially, damage the clear coat that is on most factory wheels. Further, if you don't have clear coating on the wheels, it could be even worse considering that unprotected metal is very prone to pitting and other problems from chemicals.
Your best bet it to utilize a chemical, whatever it may be, according to the manufac's recommendations and dilutions. Pay special attention to where you're spraying it and, under no circumstances should you let the chemical dwell on the wheel for long periods of time.
Here's my procedure:
1. Wet entire vehicle including wheels, wheel wells, and asphalt beneath the tire.
2. Apply Citri-Gel to the immediate surface of the tire and move to the other tire on the same side of the vehicle and repeat on that tire.
3. Return to the first tire and, using a nylon bristled brush, agitate the chemical helping to release the stubborn stuck-on grime.
4. Immediately rinse tire one.
5. Repeat for tire two.
6. Spray entire vehicle again and rinse driveway/asphalt so that the chemical is diluted and won't cause problems on the driving surface.
7. Repeat on the other side...
Under no circumstance should your tire brush be used on any other portion of your vehicle with the only exception being wheel wells. I recommend keeping a flushing amount of water on the wells when you spray your chemical so that you won't have any potential pitting or other problems with any metal parts that may be exposed in your wheel wells (ie: Springs, brake lines, etc...). Rinse well!
I hope that helps!
RP
I hope that helps!
RP
What I used for years...until I had my BFG's mounted with the letters on the inside...Ajax and a nylon brush. Always got the white letters spanking clean. If the white on your letters is rubbed off or scraped up you can re-paint them. They make paint pens to do that. Like this.
Originally posted by lifeguardjoe
Personally I like 'Spray-Nine' mostly because I can't find Wesley's Bleach-White anywhere around here anymore! Oh and I use a nylon bristled brush.
SL
