Do I need to polish my wheels? (pics)
I have American Eagle Alloys AE-186 and have a so-called "super finish" After about a year or so, they don't look so good. I'm not 100% sure what they are made of or if they have a clearcoat or what not but I was wondering what the best way to get them looking better is and what products I should look for. Here are some pics of my worst ones.
Thanks guys.
Thanks guys.
I'd start with just washing them with soapy water and a brush and see if the rims are pitted or stained enough to need something stronger. I'd then use something safe like Simple Green and elbow grease and seeing if that will clean them up before going to the next step. Acids or other chemicals can cause more damage than they fix.
Yup, that's exactly what polished aluminum looks like when it starts to oxidize. Although I never let my American Racing polished aluminum wheels get quite that far along, they can be saved. I'd suggest that you'll need a buffer and some decent polish to bring them back though. I use a rotary buffer with foam pads and it takes me about 5 minutes per wheel. Of all of the polishes I've used, a product called Wenol has worked the best at bringing back the "chrome" look. You might consider a sealer called Zoop to seal the wheel after you finished buffing. It slows the oxidation process down. Have fun!
F me. how much is one of those buffer doohickies gonna cost me? Will an idiot like myself be able to do this without screwing something up? Can I do it while they are on the truck because I don't think my jack is high enough to get it off the ground. So much for my "super finish"
I'll keep you guys updated.
More bad news big guy. You're really going to have to pull the wheels to get them back to their original luster. You can try polishing with them on the truck (like I used to), but I think you'll find that lug nuts and center caps just get in the way. As for the "buffer dohickie, a decent rotary buffer in under 200 bucks with a pad. Yes, this is why plated (chrome) wheels are generally worth the extra money. Don't worry though, I've got my "polish the wheels" drill down to about 1.5 hours - including removal of all four wheels.
Trust me I am new....I have driven beaters for ever but I have seemed to have picked up a gem.
https://www.f150online.com/galleries....cfm?gnum=5637
I need to know how to clean the black portions behind the rim. I am not sure it this rim is chrome or aluminum.
Hey there. Before you go out and spend your money on one of those 200 dollar things you should try this.
http://www.autobarn.net/05140.html
Trev
