Anything work as good as clay bar?
What is it you are trying to remove?
Clay bar is widely used here on the site for removing a host of gunk from your paint, however I don't have one. If you're looking to remove tar, bugs and winter road grime build-up try WD-40. Spray it on and let it soak for a few minutes then wipe with a clean towel. You'll have to give your truck a vigorous wash after to remove the oily residue and of coarse you'll have to re-wax as the WD-40 will strip the old wax as well. But it gets rid of all that crap, costs less, and can be used on paint, glass, plastic, chrome, and aluminum with good results.
Hope that helps!
Hope that helps!
Originally posted by SuperCrew02
I have a white truck which is really easy to keep clean. I have noticed some rail dust in the paint that I would like to get out. I have used a clay bar in the past but was wondering if I could use some type of cleaner instead that would take less effort.
Clay is really your best option. There are chemical peels and such but, it's really not going to address embedded/bonded contamination like rail dust.
RP
![Big Grin](https://www.f150online.com/forums/images/smilies/biggrin.gif)
I just stumbled on to some video produced by AutoMagic, about their ClayMagic product, and although I probably won't be using this particular brand, I can not wait until I get a chance to clay my truck!!
I have what I think is a pretty bad bonded contamination problem, so I am thinking that claying will give me a sweet result.
Where is this video?
ClayMagic is what I used, just because it was cheaper, but looked the same as all the others.
Chris
Chris
Chris
http://www.automagic.biz/StreamingVi...Raceway-HI.wmv
Thar ya go! It's basically an ad, nothing to exciting, but I guess it's worth watching.
I use up what seems like a lot of the lubricant. Had a third of the bar untouched when I ran out. The lubricant cost as much as the kit, so I bought another kit, Now I have 80% of a bottle of lubricant, and an unused bar. I was hoping that a video would show me I was using too much lube, but they seem to be using only slightly less than I am.
Oh well, just need to drop the clay more, and it will average out...
Chris
