Scratches, swirls, and spiderwebbing - Your days are numbered.
#78
on
Thanks y'all, but it still needs work. I'm not holding myself to RP standards, but it's still got a few blemishes in the paint that need more work. Time and (mostly) weather is conspiring against me. They said it was supposed to rain last night, but we're still in an overcast right now, sun's trying to break through the clouds.
#79
Originally Posted by ddellwo
Hey RockPick:
In looking at the different G100 packages they have put together, which one do you think is the best bet for someone who has been detailing vehicles by hand for awhile, but has never made the "leap" to a machine?
As for the kits, I'd probably look pretty hard at the #2 kit. To me, that's just about everything you'd need. There is a product in there that I don't care for (Speed Detailer) but, you might love it. Either way, it's a VERY good deal on the kit IMO.
RP
#80
Q,
EXCELLENT JOB!!!
Give it a little bit of time now... you've managed to get your hands dirty with this and are learning the ropes with the machine... once you've used it a few times, you're going to feel pretty spiffy with some of the results you're going to produce...
As for the #9, generally speaking, you should work it until it's almsot dry (not dry, almost dry -- never work a product until dry). Simply put, it should be slightly moist and wipe off with not a lot of effort.
#80, which is very similar to #9, will start to 'ball up' when it needs to be removed.
Again, EXCELLENT JOB!!!
RP
EXCELLENT JOB!!!
RP
#81
on
RP, thanks dood. Wasn't all just me, guidance from you and everyone else around here got me going too. As I said, it still needs more work. There's still some swirling and light scratching on the tailgate, but they're *nowhere* near as noticeable as before, which I can totally accept, but if I can make it a little better...which begs the question, should I keep trying repeatedly with #9, or should I try stepping up to #80? According to the numbers on the bottle, #9 is like a "3" and 80 is a "5." I need to order some more pads so I don't cross contaminant with different chemicals, but in the meantime, what should I do next?
Edit again - I also learned what a complete and total pain in the *** #26 is to remove if it dries. I'd imagine this applies to most any "pure" wax though. Also, after using #9, on certain sections of the truck I'd get some pretty heavy dusting. I wasn't exactly sure how to guage when to reload the pad with more product. I more or less worked in an approximate 2x2' section. I spread an X on the pad, lines maybe 1/16" wide, smeared it on the panel and fired the PC up while the pad was still on the panel. Remove from that panel, add another X-line's worth of #9, and move on to the next panel. This worked good for the tailgate and the hood, but this morning I tried doing the passenger's side rear of the A-pillars and got some pretty serious dusting coming off the pad. What did I do? I came in tonight and rinsed out that pad with a little bit of Dawn and some warm water, and I'm letting it air dry now.
#82
Originally Posted by Quintin
... should I keep trying repeatedly with #9, or should I try stepping up to #80? According to the numbers on the bottle, #9 is like a "3" and 80 is a "5." I need to order some more pads so I don't cross contaminant with different chemicals, but in the meantime, what should I do next?
It certainly won't hurt anything to jump up to #80 but, if you've seen a significant change based on your past performance, I'd guess that #9 might get it closer to where you want it with a few more applications... If you do go to #80, I'd recommend an extremely good cleaning on the pad that you utilized #9 with.... Potentially a new pad... IMO, going up on the scale of cut isn't that bad... going down would be a bit more cumbersome.
For example, if I had just utiled #85 Diamond Cut, I wouldn't want to use that pad with #9 but, after using #9, I would be more apt to go to #85 with little thought because of the cutting power differences. While you should always go with a clean pad, I'm offering more of an opinion than a preference. I do it both ways when going up... never when I'm going down products.
Again man, it's a tough call via the boards without seeing it...
What did I do?
For exactly the reason that you described, I will almost always either spin my pads out on my rotary and/or PC to remove the 'dust' and dried product that is left behind in the pad; even after washing.
To aid in this dust removal from the pad, I'll utilze a very soft nylon brush on the pad while spinning it. A soft toothbrush works REALLY well...
RP
#83
on
Originally Posted by RockPick
That's a very tough call without seeing it Quintin. I'm not sure exactly what to tell you honestly.
Actually, #26 is really easy to remove. My hunch here is that you probably applied it too thick... Remember ultra-super-duper thin coats with any last step product (LSP).
#85
Pads are cheap enough as is, and I need to order a few (okay, a bunch) more anyways, I had every full intention of dedicating pads to specific products anywho.
Not sure what you meant by more camo with the NXT... NXT will further darken the paint.
That's possible, I didn't think of ultra-super-duper thin coats, I just kinda swirled the applicator around a bit in the tub and went to town. I got up this morning and still saw some residue from #26 on my hood, but a shot or three of #34 took care of that. Just seemed awful difficult to remove, especially compared to NXT.
It will, however, leave shadows if not applied evenly (darken the paint in some places and not in others) and thus, this is another reason for AT LEAST two coats. Also, like I said, NXT will further darken a little...
Hm, that makes sense. Yesterday evening after my first passes with the PC, I came inside and didn't bother cleaning the pad, figuring I'd be back at it tomorrow. Hit that first panel and POOF, dust everywhere.
Keep in mind though that the PC isn't going to really give you big time 'RPMs' as it doesn't spin in a hard-fast pattern/speed. I'll typically kick it on 4 or 5, hold it out away from me and 'tap' the toothbrush/nylon brush on the pad in several areas repeatedly. You'll see the dust fly...
#88
NXT will help in an ever-so-slight way... in fact, I'll go out on a limb here to say that you may not notice anything at all...
While it won't hurt, I don't know that you'll see it help either. The cleaners in NXT are so incredibly light that I'm still baffled that they list that on the bottle... It's really a stretch in my opinion.
#89
Hey man... sorry for the delay... been out of town all weekend for my HS class reunion.
No problem -- thanks for the response.
I'm thinking I will have to break down and get one of these things with my new truck coming in Medium Wedgewood Blue. I've never had a vehicle in this dark of a color before, and I am preparing to have an infinitely more challenging time keeping it looking the way I like.
I guess time will tell if I look back and wish I would have gone with the Oxford White instead!
