Can i use vinyl cleaner on the black plastic exterior trim?
I know a little bit about plastics, and I don't think the bed-rail caps are vinyl based. More likely ABS, or an ABS blend of some type. I doubt you can "clean" them back to black, as the graying is most likely UV damage. I think this has been discussed here a little bit in the past, might find more if you dig through the archives.
To remove any wax from the rails you can buy a can of "Tuff Stuff" interior cleaner (its in a yellow can with red top) from your local auto parts place. Auto Zone and Wally World both carry it here. Use this and a soft brush to remove the wax and wipe it dry with a towel.
While your at the parts place pick up a bottle (its red) of "Back to Black" and follow the directions on the bottle.
Been there done that with my '01 SCrew when I had it and it worked wonders...Might take a couple of applications but it will work......
