white lettered tires
Old 08-04-2005, 08:11 AM
breuter's Avatar
Eagle One
Personally I like to use Eagle One wheel and tire cleaner and a Brush. Spray the cleaner on, wash the rim with a sponge, then scrub the tire with a brush, doesn't take much work, and looks fantastic.
Old 08-04-2005, 12:14 PM
Sick05Lariat's Avatar
I use cheap-o armorall foaming tire stuff with a tire brush, but still never gets that "new" white look until after i follow it up with the mineral spirits. I dislike double cleaning anything....but not as much as i dislike dirty lettering.
Old 08-04-2005, 02:40 PM
Dkory22's Avatar
This worked great on my white letter tires but I can't find it at murrays anymore! I only bought it last year.
Old 08-04-2005, 07:44 PM
All these things mentioned are great but none are quite as easy as Simple Green. Its biodegradable, so if you get thirsty you can take a sip and it wont even kill you. But it will put the life back in your tires. Apply a little Wet an Black after this to keep that shine for weeks, not recomending you drink this one though. Or either for that matter.
Old 08-04-2005, 11:39 PM
loco63's Avatar
i dont have a problem cleaning them. i know how to do that. i just thought id add the fact that i hate the "raised white letters" on my truck tires.
Old 08-05-2005, 07:35 AM
bronkx1's Avatar
My grand dad for as long as I knew him used soil aka dirt with a wet rag and it worked very well for him.
Old 08-08-2005, 02:42 PM
Dad's Hoss's Avatar
Ever consider taking going to a tire shop and having them turned around so the black side is out?
Old 08-08-2005, 04:58 PM
I tried that, the BF Goodrich's that came on my Screw are "unidirectional" or something like that.
Old 08-08-2005, 05:17 PM
craig41071's Avatar
yeah, SOS pad works best and you can reuse it 2 or 3 times
Old 08-08-2005, 05:19 PM
craig41071's Avatar
Take the right tires and switch to the left side think about it, white letters would go to the insides and tire would still turn in the same direction as it does now. PROBLEM SOLVED!
Old 08-08-2005, 06:19 PM
That made me think so i went outside to check....
I'm not sure how to explain it, but in short, that won't work.......i'm pretty sure. :o
The tread pattern on the inside of the tire is completely different than on the outside. It would be like "going against the grain" of the tire.
It's almost like a "forced advertisement" from BF Goodrich.
Maybe im missing something REALLY obvious, but i dont think so.
EDIT:PIC
Old 08-08-2005, 08:35 PM
DrPaul84's Avatar
when you flip the tires you dont flip em an put em on the same side, you flip em an put em on the opposite side of the truck...theres always an outside....or something like that lol
Old 08-08-2005, 09:35 PM
01SILVERGT's Avatar
Simple green here! Works like a charm and the tires look new every time.
Quick Reply: white lettered tires
