Polishing/ Wax Bonnet Question
To the experts: I last detailed Hoss in Nov. Looking at doing a total detail again soon. Question is, I haven't used the applicator bonnets since November. What is the best way to clean them for reuse? I have about 6 blue bonnets and two fluffly wool bonets.
Thanks in advance for the advice.
P.S. - I used many different Meguiars Products with them, from polish, swirl remover and wax ect.
I second Intel's thoughts.
If you opt to run them through the washer, I'd recommend utilizing liquid detergent so that you don't run the risk of non-dissolving detergent crystals having the potential to ruin your finish with a bonnet that didn't rinse well.
I'm a foam guy too. I rarely, if ever, use bonnets.
RP
RP
I clean my pads... they're simply too expensive to discard after one use in my opinion.
I do, however, dedicate products to pads. For example, I'll only use #16 Professional Paste Wax with a certain pad. My typical life cycle on the pad is three or four uses before it becomes 'questionable' and might get tossed.
RP
RP
Originally Posted by LsuSuperCrew
I got a question on the foam pads. Do you clean them or are they something you use once and throw away? If you do clean them what is the best way?
I'll also only use pads for certain things. If I compound with a pad, then that's all that pad see.s If I use a pad for a polish, then that's all that pad will see, etc.
