Best way to repair fender flare on FX4?
A few weeks back I bought a cheap rotary polishing tool at Harbor Freight to wax the truck. I guess I was too aggressive around the fender flares because when I was done I noticed it had partially removed some surface on the flares. Instead of being black, it left a gummy white residue. I tried scraping it off with my finger but it still remains a little discolored. I was going to buy some Vinylex at Pep Boys, do you think this will do the trick?
BTW, I returned the rotary and got a PC. What a difference!
Without seeing pictures of the damage, diagnosing your problem will be a bit difficult. A common problem with rotary buffers is heating things up as you burn through them. ( I know that sounds scary, but it's the truth.) The heat caused by friction from those bad boys can do all sorts of damage. Generally speaking those things are capable of removing material at a rate much faster than most of us are capable of managing. (Ask me how I know that.) You'll be much better off with a PC. So, can you post pics?
Looks to me like you may have rubbed the texture off of the plastic as well...
I don't know how to fix it short of a new flare...
Others have reported a 'whitening' of their plastic parts and pieces when exposed to abrasion (ie: Mr.Clean Magic Eraser)... I don't think Vinylex will do anything at all for it.
One of the 'back to black' types of products may be a better bet before I bought another flare...I don't like this type of product but, it's probably cheaper than a flare... you'll have to reapply several times probably and continually touch it up.
Best of luck but, I'm stumped here... looks like a lesson learned unfortunately. Let us know!!
RP
RP
Originally Posted by cscoios
WOW! Mother's Back to Black did the job. Put this on a couple days ago and looks awesome. Thanks to all for the suggestions, really impressed the way this turned out.
Originally Posted by 04Lariat05kr
has it come back, because any plastic protectant would of got rid of it, but once it comes off the white wax comes back.
