Problems with pin stripes
I used to use the 3M adhesive remover when I was a painter. The funny thing about pinstripes is that they are all different. Back in the old days...the main manufacturers of pinstripes was 3M and Arlon. If you were lucky in removing the stripes with most of the adhesive coming off with them, then a little 3M adhesive remover would take care of the rest.
I don't think I was clear in my earlier reply...the stripes have to be removed first, then the remaining adhesive. 3M adhesive remover will not remove stripes, just adhesive.
There are many ways to remove stripes. Heat, razor blade, friction, just to name a few. Heat works great on stripes and decals that are in pretty good shape. The easiest thing to do is put the car in the sun for about an hour then start peeling. Razor blades work if you are proficient in using them. The key is to not scrape off the paint (takes years of practice). Friction, via 3M stripe remover or "The Eraser". They can be purchased at a Auto Body supply store. They work using a drill or air tool. They work quick but make a mess. Do not use them on Lacquer paint as they will take the paint off.
Hope this helps!
Regards,
Kevin
Hope this helps!
Regards,
Kevin
Originally Posted by boomerssc
I tried everything that was suggested to me but nothing seems to get it off. Has anyone tried that 3m adhesive remover? Is it any good?
You may need to allow the chemical that you're using a little 'dwell time' on the adhesive. In short, get it on there and let it sit fo a very brief period of time to see if it begins to break down the old adhesive.
Last resort... plastic razor blades. Obviously though, this is a risky one.
RP
Any luck boomer?
I just removed some signage from our company trailer yesterday. About 15 minutes per sign. I used acetone to remove the adhesive. Took it right off. Although I don't recomend Acetone to anyone who is inexperienced in using it. It is worse than Lacquer thinner.
I really hope the 3M adhesive cleaner works!
Regards!
Regards!
