where to buy a pc
Originally Posted by F150 Duke
What setting would I use for #80?
What setting would I use for NXT wax?
What setting would I use for #26?
This might be a help for both of you... This was put together by the admin at meguiarsonline.com... I have a laminated copy that I keep with my detailing aresonal as it's a great resource...
BTW, I typically go with the 'inbetween' number. For example, when it says 3 - 5, I'll typically run a 3.5 or 4. Generally speaking, this is my rule of thumb...
As for Z products specifically, I'm going to let Boss address that as I'm not as familar with the new Z-pc product... my hunch is yellow pad but, I'm not certain so I'll let him handle it as he's much more versed, all the way across the board, than I am.
RP
Originally Posted by travman
RP thank you very nice chart no for boss to inform me on zpc and im good. woo
Glad to help.
You'll note that you don't see a 7006 pad anywhere on that chart. The reason is that you need a rotary to achieve the necessary RPM and heat needed to get this pad to really work well. The PC simply can't fit that bill with a cutting pad... Hope that helps! G'luck and be sure to get some before and afters!
RP
Originally Posted by RockPick
Duke/travis...
RP
RP
While I have used a light cutting pad (from a different manufacturer) and a Meguiar's finishing pad with the ZPC, I most often use the yellow polishing pad. Depending on the pad, and effect I want, I usually run the PC from 4 to 5 with the ZPC.
The guide that RP posted is an excellent one... print it out, or save it to disk.
hey boss. do u/can u apply z2/z5 with a pc? is so again which pads/speed
To apply just about any LSP with a PC, I recommend using the finishing pad with the PC set to around 3.
I normally don't use a PC to apply an LSP. However, I certainly understand the benefits that others find in using the PC for this purpose.
