Gold Class Vs. NXT Tech Wax
Gold Class is a PITA to buff off compared to NXT. Last year after I bought my 02 Lariat I went out and bought the Gold Class. After one use I bought the NXT. I still have the almost-full bottle of Gold Class on the shelf, waiting for somebody I can give it to. GC also is impossible to get off the plastic pieces parts. I still have stains on my bed caps from it. NXT doesn't stain the plastic as much.
Ok now next question.... What's the better car soap? I'm currently using Gold Class car soap but like NXT wax, it the NXT car soap better then Gold Class?
Not a real fair comparison from a durability standpoint but, you specifically said 'looks'.
So, with that in mind, I'll answer this from a 'looks' standpoint...
Gold Class will yield a deeper look whereas the NXT will be a bit more glossy with not as much depth.
Honestly, you might try both, side by side, on your hood... I think you'll see a definite difference between the two. I prefer deep and wet versus glossy and reflective and thus, I'd probably go with the carnauba based Gold Class (with only those two as an option -- there are better Carnauba waxes in my opinion).
Duability... which is something to consider this time of year... hands down, NXT.
RP
RP
Actually, I think it's just I get tired of the same look/end result and just wanna switch it up (I was a die hard Liquid Glass user but just got bored of it and switched to NXT just because I got tired of the same look).
I thought NXT was alot deeper looking then Liquid Glass, not quite as durable or does it bead water as nice, but was still about as reflective as LG with a deeper look and smoother finish (end result, it 'looks' better). I still think Liquid Glass is alot more durable though and beads water better for longer and for a flat out reflective look it looks better.
Hmm... I'll probably forget trying Gold Class for this year then...Mabye I'll put a coat of LG for the winter. I wish you could find that Zaino stuff locally without having to order online. I read/heard that stuff is the most durable.
Here's a pic from last summer of Liquid Glass (I don't remember if I took the pic directly after applying LG or it was a wash or two into a fresh coat)
