Touch up paint...again
Ah, I know this has been drilled many times, but I need some help. I've got a white 03 Supercrew and I'm trying to touch up some areas. I tried the Oxford white which I think is the white used on the Lightnings, but that didn't match, and I tried Performance White and that didn't work either. Anyone know exactly what color of white it is? Now how do I get the old paint off that I put on it? Any help would be great. Thanks.
try looking for you paint code. its located at the drivers side door frame, didnt explain it that good but its the same thing that tells you the tire info and the manufacter date
as far a the old paint goes i woulnd wet sand the area and then put the new paint on also i would try to put a clear coat over that try looking into some touch up kits and ill go ahead and point out to you that even if you have the same paint code and everthing it still might not match up perfect but should be pretty close
