80 or 83
80 or 83
My truck is 11 months old now , the first four months it was taken to the car wash , then I noticed they were scratching it , even though they asurred me they use clean water and rags.I now wash it myself using the two pail methode. I have since been trying to restore it to a swirl and scratch free as much as possilble. There are small dia swirls and some long sweeping scratches way less then finger nail catching but I see them in direct sun light. The finish would be considered good to a normal person, you have to be pretty close and in direct sunlight to notice. But I have become a detailing junky and want to get to a swirl free finish in direct sun. I have been over it twice with scratch X and use NXT for wax. I just purchased a DA polisher 7424 , ordered meg's backing plate and pad kit. Now the question is how to get to what I want will the Speed glaze #80 do the job ? If it dosen't should I go to #83 or go over it again with the #80 ? Should I start with the #83 then go to the #80. I don't want to remove to much. Thanks all of you that help on this site . I have learned alot about detailing and performance products from all of you.
Picture appox. 2 month ago(f150 Ironhorse)
The kicker is that you've got a BLACK truck and thus, EVERYTHING will be apparent.
Owning a black truck as well, I have had very good luck on my truck and on client vehicles with #80 when the micro-scratching / swirling hasn't been too elaborate. Having not seen your paint, it's a tough call to make.
With that in mind, I'm going to have to recommend starting with the least abrasive product first... that, of course, being the #80. I'd probably go a couple of rounds with it (if needed) and reassess.
Being that this might be one of the first times that you've utilzed a DA polisher, it may take a little getting used to so don't be discouraged if, after your first application, you still have paint problems. Be patient. Learn slowly.
RP
RP
Based on your assessment of your paints conditon (hard to notice the swirls), if you want to "remove" (not hide) the swirls, I would start with #80 and a polishing pad with the PC set at 5 and work as follows...
Find the worst swirls.
Work a 2' x 2' area completely with the #80.
Wipe the area down with a 50/50 spray mix of alcohol/distilled water and check the area closely...
If the swirls have been somewhat reduced, make another pass with the #80, wipe it down, and check again. If the swirls are almost gone, I would step down to a finishing polish. If you don't have a finishing polish, you can use the #80 on a finishing pad to burnish the paint a bit, and finish off the swirls.
Now, if after the first pass, you don't see a significant reduction in the swirls, you'll probably need to go right to the #83, make a complete pass or two, and then step down to the #80.
If "hiding" most of the swirls is OK with you, you could start with #80, skip the alcohol/distilled water wipe down, and just wipe the area with an MF and check. Then, follow up with a good glaze like #7 or #81.
Hope this helps.
Hope this helps.
