Polishing or Waxing, whats the dif.
Often times, these two words are synonymous however; with most lingo, they are not.
I believe that they became synonyms 'way back when'... now it (polishing) refers more to the removal of surface blemishes (swirls, scratches) and bringing out the deep luster in paint.
Waxing is more along the lines of the 'final step' for PROTECTION and gloss...
They are two distinctly different items in my mind but, like I said, the generations of past may have seen it a different way...
I'm not very familar with LG so, I'm going to let someone who knows more about it comment on that...
Clear coats definitely need 'protection' (be it wax or sealants)
Just to add...
Polishing may, or may not, remove the contaminants that are on the vehicle. This is why knowing and assessing your painted surfaces is important as there's no perfect recipe that is good for every single vehicle.
As I've said in the past here and on other forums, every vehicle's paint is going to be a little bit different... knowing what products can deal with certain degrees of problems on a painted (or non-painted) surface is what can separate the men from the boys.
Any 'Joe Blow' can wax a car... it takes an enthusiast to do all the necessary 'prep work' to obtain that show car finish... it's all in the prep!
Originally Posted by Boss_429
Liquid Glass is a synthetic wax with cleaners, or an "all-in-one" product if you wish. It cleans, and adds protection. You wouldn't want to wax "before" applying it, as the LG would remove most of the wax underneath.
