i want to acetone my emblems
I acetoned my badges, but it’s an ’01. I don’t know if acetone is working on the ‘03s but I don't see why not. I know they weren’t working on the 97 badges. So if they went back to the way the use to put the black on (like ’97 and earlier) then you may have an issue.
Welcome to the Board!
You should be fine. I just did my 2002 a couple days ago and it did NOT take off the XLT. I was hoping it would though as the red has fadded to a girly pink from the cali sun. Im going to work on it tomorrow to see if I can get it completely off. You should be fine with the 03 thought.
I use brake cleaner with acetone in it, that way its not a concentrated and if i spill a drop on my paint i can wipe it off really fast and dont have to worry too much. Ill try to take some pics tomorrow and post them here.
found the best stuff for taking that type of paint off, it was made by krylon and called aircraft paint remover in a airosal can(or something close to that, will look up later for the can is at my shop). Anyways at first I tried to use acetone my emblems on my 97 just to see if It could be done and my xlt had turned pinkish, didnt even faise it after about 2 trys, had some of that aircraft remover and sprayed on my emblem, the stuff kinda fizzed up a little then I took a rag and almost all the paint came off on the first try with little scrubbing. By the way the 97 emblems have a nice jet black to them once you get that paint off.
try to post pics later
