What is this "clay bar" stuff
Originally Posted by cehowardf150
Okay, you all know I am an old timer, that is new to trucks, and new to this high level detailing too. With that said, I have seen this "clay bar" mentioned several times, what is it??
Thanks in advance..
Thanks in advance..
I'm curious about it too!
PS: Please don't judge me on my spelling
Clay is a material that many detailers/enthusiasts utilize to remove bonded contamination that is on the painted surfaces (and other flat surfaces -- like glass, etc).
The concept is simple... you're cleaning the paint (after you've washed and such) by mechanical abrasion... the clay glides back and forth across the paint using very light downward pressure and a lubricating agent (typically some kind of quick detailing spray).
As the clay glides, it snags stuff that regular washing didn't/couldn't get.
Ultimately, this yields a smooth as glass finish which is important for proper optics and such...
A quick search will yield hours of reading on this topic.
RP
RP
A painted surface should feel like a smooth piece of glass when it's at it's prime. For example, the rough texture that most will feel on their paint isn't a 'normal condition' -- it's caused by 'gunk' that has attached itself (either by sticking or embedding itself) and cannot be removed by normal washing.
Pointers:
1. You're not going to 'over lubricate' the surface. Make sure to use ample amounts of lubricant.
2. Let the clay 'glide' along the surface. You don't have to 'press down'. A simple amount of hand-weight downward pressure is ample.
3. Rotate the clay often. Knead it frequently.
4. Drop the clay on the ground and it's trash.. no exceptions.
5. Because it's painful to toss a $20 claybar in the trash (trust me, been there -- done that -- own SEVERAL t-shirts), cut the bar into a couple of 'user friendly' sizes. Store the clay in it's original container or in a ziploc baggie. Once you drop a piece (and this will happen - plan on it), and you throw it away, you'll have a couple of clean pieces in the kitty to finish your job.
6. Clay as needed. There's no golden rule for how often you need to do it. Different environments will yield different frequencies.
7. Use common sense... simple things like staying away from wheel wells and, when you are claying such an area, using a piece of dedicated clay (as it will pick up more grit and grime in this area) are important steps in securing a problem-free surface in the future... trust us, a piece of sand positioned in the right spot on a clay bar can spell DISASTER for paint so, make sure you check it often, knead it often and, again, use a lot of common sense...
Those are a few 'down and dirty' hints...
RP
Pointers:
RP
Originally Posted by Thayer
One more thing to add. Make sure you have plenty of lubricant before you start. I bought the Mother's kit that came with a spray bottle of quik detailer (or whatever Mother's calls it). I used the whole thing and had to finish up with some Meguiars Quik Detailer I had on hand.
Use only enough QD to keep the clay from sticking. It should just glide over the paint. You should be able to feel it grabing the "crap", but not "dragging" on the paint.
Yes, a "little" more is better than too little. However, too much is a waste of time and product. It takes a little practice, but you'll get the hang of it.
Originally Posted by ThumperMX113
Do you want an even coat of 'lube' or what?
I suppose I need to add a caveot to my 'you're not going to over lubricate' comment because, as Boss mentioned -- well, you can but, even if you over lubricate, you'll eventually be through the lube and the clay will be doing it's job.
I suppose this is something you'll just have to experiment with to obtain the proper 'feel' to the action.... obviously, you want to remove the water out of the pool before you repaint the deep end...
RP
