Removed 4x4 decals...Now what?
I finally removed my 4x4 decals yesterday. I know I should have done it a lot sooner but I couldn't make up my mind. The truck was built in March '04 so they had been on for almost 2 years. Overall, they came off easy and after a little work it looks pretty good. Only problem is when looking at it very close, there's a few places around the edges where the adhesive is very stubborn. Any suggestions on those areas? Will it eventually wear away or do I need to do something about it? I would take a pic but I don't think I could get it to show up.
Thanks in advance.
Thanks in advance.
3M Adhesive Remover...
This is a product that is specifically formulated to remove what you have on your truck. If I were you, I'd seriously consider it -- I believe that Wally World keeps it in stock.
Be sure to wax the entire area after you do it as it *WILL* remove any surficial protection that was there.
RP
RP
RP
RP
I used the 3M and it took the most stubborn spots off in seconds. That stuff is great! I followed up with clay and NXT and it looks like they were never there. Thanks for the tip RP. Now the only thing left to do is kick myself in the **** for wasting all that time with WD-40 when 3M would have done the job so much easier and quicker.
