"Off Topic" Cleaning Question
on
1 Post
i figure this is the best place for this..
what do you experts suggest i use to clean the screen on a
flat screen monitor?
i've tried everything and there is still streaks
water? no good
glass cleaner? no good
the best polishing cloths that i use on the show car? no good
what is the secret to these "squishey" screens?
...zap!
water? no good
...zap!
i use monster screen clean.
i got it when i bought my big screen tv. it cleans great.
i got it from circuit city.
http://www.monstercable.com/productPage.asp?pin=2350
on
1 Post
sounds good... thanks
...zap!
I now iy sounds kinda funny,but I use a qd. http://www.fk1usa.com/products-consumer.htm#425 is the best qd by far on the market imho and its anti static, so it keeps dust off it.
Originally Posted by zapster
mrs zap likes to "point out" things so fingerprints are a problem..
Meguiar's #17 is a possibility, but expensive...
$20!! I clean mine with an alcohol/water mix and microfiber cloths, works great. Here's what Dell recommends:
There are many cleaning solutions sold specifically as LCD or flat panel cleaners. Alternately, you may use a 50/50 isopropyl alcohol (IPA) and water mixture. Micro fiber cloths such as those used to clean eyeglasses are excellent for use with LCD or flat panel screens.
Wipe the LCD or flat panel screen gently with a soft dry cloth. If any marks remain, moisten the cloth with LCD cleaner or water/alcohol mix, and then gently stroke the cloth across the display in one direction, moving from the top of the display to the bottom.
Warning: Do not use any of the following chemicals or any solutions that contain them: Acetone, ethyl alcohol, toluene, ethyl acid, ammonia, or methyl chloride. If you have a different chemical or solution and are not sure whether it is suitable, do not use it. Using any of the chemicals in the previous list may cause permanent damage to the LCD or flat panel screen. Some commercial window cleaners contain ammonia and are therefore unacceptable.
