Exterior cleaning
Exterior cleaning
I have the Pirelli scorpion tires with raised white letters. I have tried tire white spray, steel wool pads, and soap and water with a stiff brush, and cannot get the white letters white. They have a yellowish brown tint to them that just does not seem to want to turn white.
Any suggestions on how to whitten up the letters on the tires? The yellowish tint makes the entire truck look dirty.
Westley's Bleach White
Ajax or Bon Ami powder
an SOS pad,
a bucket of reasonably warm water
a stiff bristle brush,
And scrub, you may have to put some elbow grease into it to get them white as new, but it can be done...
Be VERY careful using any abrasive or severely caustic products (such as many listed above). While they can 'whiten' the lettering, you are also posed with the potential problem of scouring and/or pitting your wheels.
My suggestion for high-grime tires is to go with a product like Simple Green. Spray it on, allow a little dwell time, then, with a stiff nylon-bristled brush, work it off. Repeat if necessary.
When complete (by the way, do this FIRST after wetting down your vehicle), you'll need to rewax the wheels as the SG will remove wax.
Originally Posted by RedDragon
Sounds a little crazy but my friend, a professional detailer, told me to use a smooth rock. I had the same problem as you and this works wonders. Using a cleaner will help but is not necessary.
One more suggestion on the WHITE WALLS ONLY -- Mr. Clean Magic Eraser (same principal as the 'rock' I suppose -- simple abrasion)...
I had the same issue,so I went to a local tire place up the road.There advice was to use some "Liquid Pre-Buff Cleaner".They use it on there tires to bring up the lettering.It only needs a small amount on a rag and it cleans it right up.I used it and it works.It is primarily used for preparing rubber for repairs,so that tells you that you don't want to be using it every day.
