Can't get rid of wax film...
I finally got most of the ext. of my truck detailed out after 6 hours and now I have the rims to do tomrrow. Now there is a "film" or cloudy look, you can't see it from 2 ft away but any closer you can. I washed the truck, then dryied it all, the applied Meguiars Deep Crystal 3 step system, went through all the steps and put on 2 coats of wax. All in my garage in the shade, I did everything by hand useing applicators and Microfiber cloths. What did I do wrong and also how do I get rid of this filmy/cloudy look??
Paul
Paul
I would concur that it was a lack of setup time but, I too have experienced this problem when I'm almost certain that I allowed the time for setup...
On black, you'll see this happen more often versus other colors (since black shows everything). The solution, simply wait -- give it about a day to maybe two in warm temperatures and it'll vanish. I know that sounds 'goofy' but, this is one of the EXACT reasons that I recommend that folks withhold judgment on their vehicle's finish when using a carnauba until the next day (or even the day after).
Thanks guys!! I guess that I will just wait a day or two and see what happens. I thought that I let the wax sit long enough. I waxed the whole truck, went in had lunch and watch Extreme 4X4 and Trucks (so it sat for about 1 hr). Then wiped the entire truck down, and applied the 2nd coat, waited another 45 min, and wiped it down again.... Oh well, but thanks for all the help!!!
Paul
Paul
I didn't think that on a carnauba wax you needed to wait between coats, etc. I do it wet-on, wet-off (Karate-kid style), 'cause that's what the famous detailing pros do, or so they say. I've never had a haze problem, but since I'm detailing my truck tomorrow, I'll probably curse myself saying it...
